Anx - Opel Corsa GSi 16V - Black Falcon
+24
Gonçalo.L
Fernando
David
rogeriotdisport
Anx
28 participantes
Página 1 de 3
Página 1 de 3 • 1, 2, 3
RESUMO de PROJECTO:
EXTERIOR:
- Full Body Kit Original GSI
- FK Head Lights Single A-Eye - BLACK
- Rear Smoked Lexus Light - BLACK
- Tigra Pack 2 - Air Vents
- Small Black GPS/FM Antena "Shark"
- Piscas Cromados
- Kit BiXenon 6000K
- Remoçao de Frisos e Pintura Geral
- Capot BadBoy
LIGAÇAO AO SOLO:
- FK HighSPort Coilover Suspension Kit
- Bombas de Travão GSI - 260mm
- Calços EBC Green Stuff
- Tubos Travão Malha de Aço - Goodrige
- Oleo Travão Ferroo Dot 5.1
- Barra AA Frente + Traz ( Inox )
- Barra Estabilizadora GSI 22mm
- Jantes RH-CUP 15"/7 Frente e 15"/8 Atraz
- Pneus Firestone Firehawk SZ80 195/45/15
INTERIORES:
- Volante Sparco 3 Braços Rally
- Manete Sparco
- Fole Sparco
- Pedais Sparco
- Painel Instrumentos - GSI 220
- Manom. AFR + Oil Pressure
- Estofamento Cabedal Preto + Costura Bordeau + Tecto em Camel
- Isolamento Térmico/Acustico e Corta Fogo
- Extintor FK Cromado
- Alarm Starter + Turbo Timer CARVOX
- Luzes de Habitáculo Led Branco
- AutoRadio Sony XPLOD CDX M9900
- Colunas Frontais RockFord Fosgate 65W RMS
- Colunas Trazeiras RockFord Fosgate 110W RMS
- Colunas Tweters Xplod 120W
- Kit Cabelagem RockFord Fosgate
- Thiny Woofer 150W Blackpunt
* Som nos Compartimentos de Origem Discretos
ENGINE MOTOR:
- Rebuilding C16XE GSI 1993 109hp
- Ported and Polished Head Intake/Exaust
- Piston Bore 80mm ( 1640cc)
- Head Gasket - COMETIC 3 Layer
- Camtek 16 Valves
- Dbilas ECU Remmaping Chip @ 8000rpm
- Dbilas Time Gears ( Pulleys)
- Dbilas Camshaft 266º Power Range (4500-8000rpm's)
- Dbilas FlowTek Kit Intake Manifold
- Dbilas Cold Air Intake
- X16XE Lower Intake Manifold Ported and Polished (55mm)
- BMC CDA - Air Filter
- Fuel injectors C16XE
- Fuel Pressure Regulator @ 3,5Bar FSE
- F15 - 5 Speed GearBox GSi 220
- Modded Quick Shift
- Oil Catch Can + Filter
- NGK Iridium Spark Plugs
- Magnecor Comeptition Leads 10mm Red
- Chris Asley Motorsport Coolant Hose Kit (Black Gloss)
- EGR - Blanked and ECO-TEC OFF
- SuperSprint Exaust Manifold 4-2-1 Inox
- Rally Design - Exaust Manifold Wrap Heat insulation
- SuperSprint De-KAT Inox
- JSV Inox Exaust Dual DTM 80mm
Finalizações..
carrinho esta deveras engraçado. Ronca desalmadamente. 8-)
Anx- Número de Mensagens : 19
Data de inscrição : 09/09/2009
Re: Anx - Opel Corsa GSi 16V - Black Falcon
Adoro este carro... esteticamente, tá no ponto moço, não lhe mexas mais!
Continuação do bom projecto que até agora nos tens mostrado!
Abraços!
Abraços!
Dos B's mais bonitos que tenho conhecimento, a ponto estético não mexas mais, está mesmo no ponto.
Continuação do excelente projecto
Este carro está lindo!
Só tem um defeito!!
nao ser a GASOILEEE!!!!
Só tem um defeito!!
Andre_Porto- Número de Mensagens : 160
Data de inscrição : 13/10/2009
É dos poucos proejctos k ainda me faz ir ao COPT ... muito bom sem duvida
gostei parabens a maquina
rogeriotdisport- Número de Mensagens : 448
Data de inscrição : 20/04/2009
Aí esta ele... Para mim o melhor Corsa B nacional... Parabens Anx...
QaGão- Número de Mensagens : 650
Data de inscrição : 09/05/2009
abusivo... andre_porto, ainda bem k é a gasolina...
esse B devia vir ao continente, devia devia...
Tanks pelos coments. Ainda falta mta coisa para ficar no ponto.
dps logo postarei..
dps logo postarei..
Andre_Porto escreveu:Este carro está lindo!
Só tem um defeito!!
Essa é a melhor qualidade deste carro!
Ser um GSI CRLH!!
ZaKa MaRaca- Número de Mensagens : 1092
Rostabal escreveu:É dos poucos proejctos k ainda me faz ir ao COPT ... muito bom sem duvida
tal como eu, mesmo apesar de não postar nada
mas o carro está brutal a todos os niveis. muitos parabéns
tiagolas- Número de Mensagens : 81
Data de inscrição : 28/10/2009
Idade : 44
David- Número de Mensagens : 639
ta msm bonito grande projecto sim senhora
Está muito bom, sem dúvida alguma!
Parabéns
Parabéns
Bom, como já te tinha dito e sem querer tirar qualquer tipo de mérito ao projecto, mas se há coisa que o carro nunca foi, foi um Gsi, mas sem duvida que dentro dentro dos SWAPS de aspirados é das melhores preparações que acompanhei, muito completo e com charme.
Esperamos agora que os problemas se resolvam para ver isso na estrada novamente a fazer estragos e de preferência ao lado dos VTi´s
ZaKa MaRaca escreveu:Andre_Porto escreveu:Este carro está lindo!
Só tem um defeito!!
Ser um GSI CRLH!!
Como o Pistolas disse não é um GSi, é um Sport com o motor e afins do GSi.
Mas não deixa de ser um grande projecto.
RabidWolverine- Número de Mensagens : 104
Data de inscrição : 16/04/2009
GSi de fábrica ou n está bruto seja como for ... agr claro, para verdadeiros amantes da marca OPEL n deixa de ser apenas mais um corsa B com swap
É um grande projecto, e que ninguém meta duvidas nisso, tendo em conta os investimentos que foram feitos no motor original 1.4 e nos posteriores investimentos neste motor 1.6 deve ter-se em conta a dedicação e gosto que foram aplicados no decorrer das fases, e só por ai e pelos resultados que obteve é impossivel tirar qualquer merito que seja.
Claro que o carro dispõe de uma mecânica e segurança completa que dispõe um Gsi, simplesmente tem um nº de quadro de um 1.4 com swap a 1.6 e foi só por ai que me referi ao facto de ser uma denominação errada porque um Gsi não se torna Gsi.....tem que nascer Gsi não interpretem mal o meu anterior comentario porque não foi com más intenções, inclusivé foi com bastante ajuda do ANX que desenvolvi o meu.
O meu desejo neste momento é de ver isso a andar na estrada novamente pra ser provado que os 1.6 com as suas características originais de engenharia são tão bons ou superiores aos Hondas e demais carros equiparáveis, porque nestas coisas torna-se chato ser o unico e um Team Mate vem sempre a calhar
Bem mas é preciso meter um TD na estrada a correr a frente dos VTi's? Era bom era... eheheheheh
Mas sem duvida, que é dos poucos projectos que me faz ir ao COPT... principalmente pela dedicação que o dono tem ao carro! Está de parabens mesmo!
Abraços!
Abraços!
O Carro nao é um GSi Original, Como sabem é o Sport 1.4 16V, Mas tem a Mecanica e o material do
GSi, com a exepção do ABS, coisa que nao tenho itençoes de o meter pois ja trava mt bem ate.
O motor vai ter k ser aberto para meter molas duplas estas cames sao agressivas demais para as molas de origem, e dps de aquecer dilatam e nao fecham bem as valvulas de escape.
popupar uns trocos para as molas e para uma junta.
pk compra los feitos se podemos ser nós a construi los ... parabéns ta ai um exelente projecto
jonas- Número de Mensagens : 871
Data de inscrição : 18/06/2009
migo consegues arranjar molas dessas la fora no ebay pelo menosAnx escreveu:O Carro nao é um GSi Original, Como sabem é o Sport 1.4 16V, Mas tem a Mecanica e o material do
é o k vou por neste momento e por 110€ vem todas
tens link disso?
» C. Black - Seat Leon Fr Vs Opel Corsa SI
» dable - Opel Corsa B 1.5D - Blue&Black Edition
Página 1 de 3
